XProtect Smart Wall (configuration)
System administrators define the layout and behavior of a Smart Wall in XProtect Management Client. This includes:
  • General properties, such as the name of the Smart Wall, and whether it displays status text, a title bar, or a live indicator
  • The monitors that the Smart Wall consists of
  • Presets that control the layout of the monitors, and possibly also default cameras that the monitors show video from
  • The user roles that can view, operate and add content, or play back content, and when they can do so
  • Events that can be combined with rules to trigger system actions, for example displaying an alarm or other content
What to configure in XProtect Smart Client
  1. Add Smart Wall overview to views - to dynamically control what content is displayed on the Smart Wall, first you must add the Smart Wall overview to a viewClosedA collection of video from one or more cameras, presented together in XProtect Smart Client. A view may include other content than video from cameras, such as HTML pages and static images. A view can be private (only visible by the user who created it) or shared with other users.. The Smart Wall overview allows you to drag-and-drop or send cameras and other types of content to the Smart Wall monitors.
  2. Change the layout of Smart Wall monitors - you can change the preconfigured layout of the Smart Wall monitors by changing the view layout or applying a different preset to a monitor.
Related Topics Link IconSee also
Before you can define what content should be displayed on your Smart Wall, first you must add the Smart Wall overview to one or more views. The overview is a graphical presentation of the Smart Wall.
  1. Click Setup to enter setup mode.
  2. Select the view where you want to add the Smart Wall overview.
  3. In the System Overview pane, drag the Smart Wall element to the relevant view item.
    Add your Smart Wall to views.
  4. Click Setup again to exit setup mode.
  5. Now you can start adding cameras and other types of content to your Smart Wall.
You can change the view layout of the monitors. This is useful if you need to display additional cameras or other types of content.
